Help with ECU Water temp sensor plug!
I was trying to figure out why I had a code 13 and noticed that the wires that go into the plug aint even in the plug itself but just hanging loose. So I cut back the covers and was going to put them back in but errmmm...
which ones goes in which? I noticed that the plug has a label, 1 and 2. But which of the two, yellow/green wire and black wire goes where!? If anyone can help that'll be great! :dance:
Hello bud,
Couldn't see any numbers but the striped wire goes on the connector nearest the timing belt cover :)
Vijay
Hello bud,
Vijay
I just need to know which wire goes into the plug so I can plug it back into the blue top ecu water sensor! Dont really wanna do the 50/50 chance in plugging the live in to the ground and the ground in to the live! I should get some pictures up!
you see there is a lug on the plastic housing (circled) that's next to the connector where the striped wire goes :)
just had a look at mine and yellow/green goes into b2. Not blue connector though brown on mine. 96 manual
Right, here's the wires I'm talking about! Just need to know which one goes into which of the two pins on the ECU Water Sensor!
Wooo, I'm a bit slow at pictures...! doh! Time to plug it back up and see if that code 13 buggers off! :dance:
well thats fooked it. when i did the plug change on my other zed i spliced the wires in as there was a connector with the wires, wait 2sec and i'll go disconect the plug and try to work out which it is
Cheers, I just need to know where the wires goes into the plug itself as I still have that, just it was loose when I stripped it back hence why those wires just fell out which was prob why I've had this code 13 for a while even with the new water sensor!
right the green/yellow goes where the red sploge is
hth's
:headvswal lol sorry vijay read your post as stripped not striped :headvswal
which is what I said lol
Sorry! For some reason I thought you said strip rather then stripe!? You guys are a legend! My first code 55 in ages!
Right, time to fix that damn idle of mine and hopefully that should bring down my HC levels for my MOT as I swear I'm losing a lot of brain cells every time I take my Z out of the garage!
have you reset the ECU?
Gonna do that, might just be easlier for me to pull the one in the car and replace it with the spare I got!
