Is The Power To The 6x4 Amp Enought To Hook Up My Sub Amp??
There's an amp in the boot for the 6x4's, is the + terminal able to cope with my Sub Amp??? Will be running 2 12" and a single amp???
If not, where is there a hole in the bulk head to run my + from the engine bay???
passenger footwell , you need to remove the inner wheel arch liner to get at it
do a search mate youwill find all sorts of usefull info
steve
or drivers footwell and no need to remove any arch lining
all you need is a metal coat hanger, some luck and a bit of patience.
if you need any more help then i will try to dig out the site i found the info on
Thanks guys. Used the one in the passenger footwell in the end (lucky cause the + lead was only just long enough)
Help was much appreciated.
