What PSI is the fuel
What psi is the fuel on a X32 TT, & if the boost is raised does this affect the pressure of the fuel line ?
At idle 36.3 PSI with vacuum pipe on and 43.4 with vacuum pipe disconnected. Yes the pressure is increased with the inlet boost pressure.
Thought so, so if boost was at say 1bar its about 50 psi or so ?
ย
So a high pressure fuel line needs to be about 70 psi plus
ย
ย
ย
You have to use high pressure fuel line, you can get some that is rated to 5 bar and only buy the best quality you can afford!
