my oil pressure is getting low when the engine is warmed up ! the needle only goes halfway up to the first line ( im guessing it about 20 PSI ) what kind of pressure does every one else get?
my engine has done 150,000 miles so i know all the part will be worn !
First of all check your oil level
mine is normally about 40psi at idle when warm (aftermarket gauge)
Mine is usually sitting between 20 and 25psi when warm and on tickover.
GULP.......................I hope this is right!!!!!!!
If its the stock gauge you are going by, i wouldnt take too much notice of it as they are not the most reliable, your better off getting a good after market gauge that will give you a truer reading
