Gearbox gear kits
I'm going to be running more power and i already have the famous 4th gear crunch. I havn't replaced the oil with MT-90 yet, will this be ok in a high hp car say 600+ ish.
Or does this need replacing? and what are my options?
I know OS Giken make a kit for the Zed and they offer different options for gearing, i got myself in a muddle and thought the higher ther gear the higher top end you will have but i downloaded the Quaife speed calculater and it's the other way around.
I would ideally like a faster acceleration but a higher top end so thinking something like a closer 1-3 and a higher 5th for more top end, not that i intend doing it but it would just be really nice. i would love to hit the 200mph mark.
Also adding to that would a closer gear ratio actually slow me down at some where like Santa Pod as i would have to change gears more times?
it not the gears it's the syncro's that are the problem, you'd get the same problem with a close ratio kit
The ratio's on the TT are well suited to the power deliver, personally i'd like a 6 speed with 1-4 the same, 5th slightly shorter, and sixth way longer :)
PPG also do a gear kit as well, GTART are the uk suppliers
unfortunatly unless your willing to spend the best part of £10k then your not gonna get a 6 speed gox which will havdle the power :(
OS Giken is about the best gear kit, costs about £3k to have it fitted or about £1.5k and fit it yourself?
Mike
Oh right so changing the internals isn't going to work then, so how do all the high powered Zeds currently resolve the problem?
They surely can't all have 6 speed boxes.
for some reason all the high power zeds in the usa all run oem manual box's and never have any issues??? MAC fitted a new latest spec box in his and his crunch's like a bitch??
you can get a holinger box via tomie who make a plate to make it fit to the engine but again its around £8k ish but you do get a 6 speed sequencial box ;)
Mike
So should i just fill it with Redline MT-90 and forget about it?
As spending 8k on a new box isn't really within my budget lol.
yes redline can help with the crunching but it will come back eventually, if your good with gearbox's then buy the os gear kit and do it yourself for £1500 odd quid ;)
Mike,
Do you get uprated syncros with the kit then?
good with gearbox's?? what's a gearbox :rofl:
I know a bloke who may do it for me at a good price though.
Mike,
yes, the kit comes with uprated ones ;)
its a completely different feel to the box!! feels miles better
Mike
Mike
So if the crunch is down to a syncro problem and this kit comes with uprated ones Purchasing a Os Giken gear kit will completly sort the crunching problems?
yep ;)
I had my box re-built at TDI in Lakeside Thurrock Essex at a cost of £3K this totally cured any syncro problems and added a performance clutch no idea what it would cost to put the 6th gear in hope this helps in some small way!
