Indiglo Dials Power Module Failure
Took the dash apart to find out why my Dials would not light up indiglo..
The small square block that the dials connect to is fooked.. :( looks as if it has overheated and went "pop" (large bulge in the plastic housing)
Is trhis a common issue ... ?? only been on car a month or so..
tried tapping the dials straight to 12v ... with no joy... the module must convert volage up (to ??V)..
can replacements be sourced.. or does anyone know what voltage the dials run at..?? and i can try to source a converter..
cheers Brian
(flikz)
go on e-bay.com usa mate there about a fiver bud, hope this helps
Thanks M8.. :)
Had a good look on E-bay USA last night.. just tried again... nothing came up not even a full set for the Zed listed..
anyone know where I could source locally..?? or what the converter voltage value is..??
B
item no 220086454133 is that what your after or try 150097220414 hope this helps
Top Bloke :)
the 1st list ref. is exactly what I'm after..
Inverter that's the word.. just could not remember what the wee box was called..
Thanks M8
I will place an order right now..
flikz
