runs lumpy when cruising?
I have done a search but not realy found anything
when accelerating engine runs fine, but when just holding steady speed engine becomes lumpy, any ideas please ? :confused:
could be a miss caused by dodgy coil pack or injector connectors - check those are ok & no signs of corrosion. replace or clean as ness
have you checked your plugs?
check your O2 sensors, either with a conzult or putting the ECU in diag mode 2
clean connectors to PTU
Cheers Paul will look at all that tomo :)
What fuel did you last put in?
Normal unleaded...
Did what paul said and now misses all the time ! :mad: so must be one of the connectors thats to blame
Have another look tomo..
Normal unleaded...
Opps...... wrong account!!
Just took car out, didnt miss at all this time :confused: :headvswal
