Hi,
Can anyone recomend a good sealant that can be used to seal in a lamp unit? Thought about Tiger seal but wondered how easily I could remove the lamp if I needed to as I believe tiger seal is more for a permanant fix?
Vijay
Hi,
Vijay
I always use CLEAR(TRANSLUSANT) SEALANT.Available at any B&Q or similar retail shop.
Cheers bud. Any ideas if it can be painted over?
Lost me Fella,is it to bond back in the glass to headlight that your asking?If so that stuff will do the job but confused as to why you would wont to paint it.Please clarify.
no mate I need to seal in a rear light unit ;)
Vijay
the problem with those are if I need to remove the lamp, been told although it stays flexible, it has a very strong bond so removing the lamp with be a nightmare.
Theres always "NAILS"LOL.Is it for the rear lamp bonding in.If so give Luke a bell at The ZCenter Bud he will probley help you out with the proper black strip stuff.
Cheers bud, pretty sure that black mastic strip stuff is available from the local Nissan's pretty cheaplyly :)
Vijay
