Posting for a friend who's Z is porly and wont go above 2000 rpm. Seem to recall reading about this somewhere before.... any help appreciated.
Yes sounds like the "get you home" mode after the airflow meter has failed.
Check the connections to it are clean under the panel between the headlights.
If the AFM has failed then they're not cheap from Nissan so get a 2nd hand one on here ;)
Thanks all- will check it out for them at weekend. Sounds conclusively like the MAF
