Digital clock problem
Hello chaps. Just lately (this seems to happen when I haven't used the car mon-fri)the digital clock doesn't come on for about 10 - 20 miles. I assumed it was a slightly flat battery, especially as the weathers been freezing. Also when I turn the lights on the clock dims, it's always done this, is it correct ?
the clock is ment to dim with the lights switched on, the problem you have got could be a very easy fix, if you are handy with a soldering iron, if not there a few people on here how may have a look at it for you, myself being one of them.
cheers
Rob
Cheers fella's, I suspected the clock and climate control dimmed when the lights are switched onbut I didn't know about the clock not coming on all the time. Merlin, I'll probably be in touch about a helping hand with the soldering if thats ok with you ?
Hi Dave,
See you're finally back with us.
Did you manage to find the link for calendar payments?
I wish mine dimmed with the ignition on, or that i could go back in time like the clock tells me each time i switch the ignition on!....You're lucky to have one that doesn't have a mind of it's own!!;-)
No problem mate :dance:
