F.A.O. Graham S
Graham. I have found the stop pins BUT! sorry mate they are broken. I was furious when i found them The base of the pins are still intact but would need some kind of pin super glued to them (see pic) if you want to have a go I will send them to you mate. Sorry.
No problem mate, thanks for looking anyway.
Unfortunately it was the pin bit I needed.
Graham.
Graham.
Let me know if you have any luck mate. I have some precision tools and will try and drill the base of the pin and insert new pins if I am successful I will let you know and send them up later this week buddy.
Vini
Vini
the pin should pull out and replacement ones push in, i pulled mine out when i put the indiglo dials on and popped them back in
Hiya Carl. The pins are the problem mate. I thought i had two for Graham but when I dug them out they were snapped off just above the base. So I will endevour to fix them as the base is the important part. Thanks anyway bud.
