Anyone near cannock walsall etc that could help
hi gonna check my cars probs later on today
I may need a new PTU anyone local prepared to come and just swap theres onto mine just to see or if they have a spare etc
thanks chris
07914 888894
Geoff at Zedworld has just phoned and offered to fix my car great service
and hes local
Hmmmm thats funny, how would a banned member be able to read your post??? Unless of course they were using an alias... :nono:
I beleive this is what he was banned for, approaching people to tout his business when he was not an official trader. Glad to see he still does it, all this does is justify his lifetime ban bwahahah..
Make sure you check all your body parts are still there whan you get it back
oh well i never knew he was banned i thought id just mention someone had offered to help
I have kept very quiet about this though Jeff touting for business on this forum again is not acceptable
I am sick of seeing his name here
After all the problems I've had in the past with him, he is still trying to get members business
when he was finally banned I thought good riddance
I spent over £2000 pounds at least getting my car fixed after he supposedly fixed it
He may have cleaned his act up but touting for business again sounds like he is still up to his tricks
Avoid at all costs
Because of the closeness of Zedworld to this guy and wanting sorting out smart like with a visit to home as well, I TOLD HIM !!
Hope that explains things...................
btw, yer getting even quicker mate, only took yer 5 mins this time to spot summit regarding jeff that could be turned negative for the other sharks! :rolleyes:
cheers
smithy
Taken from the official notices forum...
Due to the amount of complaints that have been received lately regarding unauthorized trading on the forum, It has been decided to draw attention to the AUP, and the section which states;
Commercial Posts
Commercial posts by unsubscribed traders will be locked or removed if posted on the Forum. A commercial post is defined as any post by employees or their associates that benefits either, directly or indirectly the company involved. Use of the private messaging (PM) system by unsubscribed traders is not allowed.
I'd just like to say that I have had my car in at Zedworld just after I got it 3 times and it came back brilliant every time. The items he sorted are still holding up 3+ years down the line. I also know he wasn't this good with everyone.
Ivan
Commercial Posts
Erm right, and this is earth bud..................
Am sure theres something in that lot which your trying to tell us :rolleyes:
Man, has this been bugging you since last week!
smithy
tbh there was no mention by smithy that he used the PM system to contact SWBZ.
SWBZ supplied a telephone number and smithy could have phoned him for all we know so i dont personally think this contravines the AUP.
so everybody chill out and finish having a good weekend.
gaz
Yup :) oh and neither this guy or Zedworld are subscribed, so no PM's in either direction.
cheers
smithy
In all fairness everyone I just want to get my car fixed Ive payed two insurance premiums so far of £400 and drove around the block a few times, when it worked. Jeff whether you like him or not has borrowed me some stuff to see if I can fix it. the bits hes borrowed me the ecu is now happy theres no fault codes but the damn thing has no spark.
time to check each individual coil pack to see if there is a spark on any plug.
I already suggested that TWO DAYS ago!
whats that phrase about leading a horse to water??????
Several of us are trying to help you mate but unless you follow a logical "fault elimination path" you will struggle to even find the fault let alone cure it.
Ive already tried the first 4 coils and it makes no difference changing them around etc no spark dont worry slick pete I know exactly what Im doing it just doesnt help the main sympton I have is the car has only failed to start since I pushed the plug on properly on the PTU and cleaned it I now have a second ptu but no difference so the only thing left now is some wiring some where has broke but on first inspection the wiring looks perfect. or I have a second duff ptu.
it also doesnt help the ecu is returning code 55 at least before it had 3 fault codes
itll be broke for spared unless the laptop check brings up something
funny my first Z was the most reliable car zive ever owned
Right!
So no spark at any plug.
Move one step back.
Any output from the PTU???
check all outputs.
No output means moving back the next step to check input.
Output all present means fault lies between PTU and coil packs
Input to PTU present but no output means PTU is faulty.
Ok some kind of success the car has decided to fire up I just pulled a ta few things in the engine bay
the centre two cylinders have no spark so it is running on 4 cylinders but better than noubt
the chances of 2 coils being down are low
so now Im left with wiring prob
or spark plugs so fuel soaked there not clearing even after 15 mins revving up
May be a low chance but in any logical test procedure you need to eliminate the possibility by swapping them with known good ones.
Then work down the wire route to the PTU and beyond.
One logical test at a time will always(eventually!) lead to the problem.
ok now only 1 coil is missing
when you take the plug and coil out it sparks like a mad man so that tells me theres no fuel getting in to the middle drivers side cylinder.
sometimes it starts to run perfect etc for a second but as soon as you rev etc it starts to play up again
thanks chris
the injector connections seem ok
You now need a Noid light to check for a signal at that injector.
Simple test and one that Andy Duff told me about recently. so I bought a set.
now fixed thanks
all this rough running bright green furry lol! injection plug
now cleaned and woooohoooooooo put me foot down woooohooooo!!!!!! :duffer:
