could someone technical who has datascan have a look at my log
i have a datalog file and wondered if someone could take a quick look at it.
i started at tickover for a bit then raised the revs to over 2k then held it there then let the revs drop to idle again.
i just wondered if someone in the know with datascan log analyser could check to see if i have any problems. it just looks all pretty to me lol apart from i think i have a lazy left bank o2 sensor.
edit file is too large to post on here if you are willing to help can i email it to you please
:hyper:
bump . please anybody.
legrath
paul@swz
greg
andyduff
topless
ummm anybody else who i havent mentioned lol.
really you need to take a drive and put the engine under load at all rpm's so we can see what happens then, at idle there will be very little to see but if you want to mail it to me at retro620ti@aol.com i will see if anything stands out bud , i spent a few hours looking at my own logs so its pretty easy to see things wrong
sent thank you very much :hyper:
LH o2 sensor is slightly lazy but not by a lot , the left one is still above .7 volts so give a capable signal to the ecu, fuel base is good and everything looks rosy, go put it under load and see what happens.
thanks mate i will do a load chart tomorrow. :hyper:
just I quick question I thought data scan only showed combined o2 as the screen shot only shows one value ?? is there another menu i can acess to see them seperate??
richard
O2 sensors should both be 'bouncing' about the scale when warm and revving.
I can email you a log from my NA as a comparison (it's the only car I've logged so far that seems to have two working o2's). (Touch wood!)
...is there another menu i can acess to see them seperate??
richard
Yes. Go to Setup and choose what you want to see and where.
