Please help - problem wiv zed !!!!
Right i dunno what has happened but i fitted some dumpvalves last weekend and a few days later shes playin up. in order to get the old dumpvalves off i had to uncilp the fan at the front. its all back together and working now and when im driving the fan seems to come on while im driving, and the car seems to get really hot, the temp guage next to the dials goes into the red and i s**t myself. ive got a slight leak in my water pump but i make sure that shes topped up wiv water. can anyone help me, wots goin on?????
Its out of coolant
The secondary fan is hardly used anyway so if its overheating you need to get that leak fixed before you destroy your engine.
I hope you didn't fill out your insurance forms in that txt spk it will double the premium ;)
You may have an air lock in the system which makes it look like it is full when you fill it up.
As above you need to fix the leek first.
Then see what happens.
Darrell
When i was taking my motor to bits I found that same prob when all back together.
The prob for me was the sender connectors from the upper rad pipes . I just wiggled the connectors...prob sorted.
But best to just check coolant level, make sure no air locks and that everything is tightened up correctly. its very easy to disturb the zed :D
