February 22, 200719 yr im fitting new dials today hopefully and wondered how to remove then safely as ive heard that it can be tricky!? :confused:
February 22, 200719 yr Just done this the other week...... To remove the stop pins, simply grip them (not too tightly) with a pair of pliers and pull upwards. As for the needles, if you need to remove them, use a flat bladed screwdriver and place this under the centre of each needle, and twist it slowly so as to push the needle upwards. Take note of the positions of the water temp and fuel needles, and replace in the same places...... Before I go into loads of detail regarding the other needles, let me know if you need it, and I'll gladly type it up ;) Dave
February 22, 200719 yr Just done this the other week...... To remove the stop pins, simply grip them (not too tightly) with a pair of pliers and pull upwards. As for the needles, if you need to remove them, use a flat bladed screwdriver and place this under the centre of each needle, and twist it slowly so as to push the needle upwards. Take note of the positions of the water temp and fuel needles, and replace in the same places...... Before I go into loads of detail regarding the other needles, let me know if you need it, and I'll gladly type it up ;) Dave type away as they just arrived in the post wahoo!!
