Right picked up the car today and have a couple of Q's.
The car in question is a 92 TT manual swb slicktop import
1) The car has 2 alpine stereos. One a cd player/tuner, the other a mini-disc player. The cd player/tuner only seems to go to frequencies upto 90.0 and therefore cannot get any decent radio stations in my area. Is this because its a jap imported stereo too? It also doesnt like to play copied cd's lol.
2) The alarm fitted is a Micro DLR4HD. Do you think this would have been fitted in the UK? The central locking doesnt seem to work correctly. Are the 2 front doors controlled via rods as when I unlock the door it makes a kind of a buzzing sound and doesn't seem to stop until I shut the door and then it auto locks itself. I have to open the door with the key (doesnt work off fob) and then I close the door too with me outside still and the door auto locks and have to open it with key again... not good if I leave the keys in there. Any ideas on this?
3) Is the heating powered by one of the aux belts that also runs the aircon?
Would appreciate if anyone can give some advice on the above.
Thanks again.
PS - loving zed ownership, going to take some getting used to with kmph speedo and all the controls in the car being completely different to any car i've had so far including the 200sx s14a.
Chris
I can help with the radio - that's a Japanese one. It will pick up UK stations but you'll need a band expander wired in. I think they're about £10.
the stero needs aconvertor thing which is put in line with the arial which lets you got the other signals.
the heating is not powered by air con belt unless air con is turn on. where in shropshire are you mate, i'm shrewsbury area
Yes the heating was working fine before but it isn't working at the moment for some reason. The fans don't come on at all when I adjust the high or low blower setting.
I'm only in Bridgnorth mate. 20 miles away.
The belt which powers the aircon seems to have been removed.
thats not a problem my last zed never had the belt for the air con on either mainly due to the pump being seized, heater blower still worked, check your fuses or could be switch or blower gone
Its a jap import so are the fuse diagrams all in bloody japanese? Any diagrams on here and where the hell is the fuse box located lol?
Only picked up the car 2nite.
Not too far away there then. Do you know where clun is/ if you can get down to Clun this week end i could look over it for you. dont know loads but know the basic's if you like
Cheers for links, very helpful...so it will be the aircon blower meter for the fans?
