main bearings
hi guys,
i've noticed knocking when starting car, diagnosis is main bearings (shells) etc. sorry not the most mechanically minded.
where would i get them from and who would you guys use to get them replaced - i'm in east anglia but can travel.
have you guys had it done and would you recommmend anybody and how much did it cost you?
Crank may have to be re-grounded too. ( crap )
hi guys,
The problem is as you have said ^^ people replace a bearing or 2 from underside of car with sump off, refit and within 100miles or less it can go again, as there may be some damage to the crank, ideally your looking at engine out bottom end stripped, crank measured and possibly re-ground, main/big end bearings, gaskets etc, you then have to think why did the bearing/s fail in the first place oil starvation. oil pump, clogged oil feed, IMO i would do the following if it was me!
engine removal
crank checked reground if needed
big and main end bearings
oil pump
rear oil seal
front oil seal
cambelt, tensioner, waterpump, thermo,
relevant gaskets to bottom end
good time to change the turbos, oil feeds :o
bearings can be got from mjp on here, or if someones doing the work, there better of ordering relavant parts same time
check traders section on here for your nearest garage :)
cheers greg
you could risk doing the bearing/s in situ allow a days labour and a few quid for a bearing or 2.
someone will be willing to do it. And its not greatly difficult to tackle yourself, although you will need an engine hoist to hold engine whilst you lower crossmember
if you want a how to email me at greg300zx@hotmail.com
cheers for that greg - i've got the funny feeling i could be in touch if i hit a snag - (more than likely) - gona take engine out i think as gonna put in uprated clutch at the same time, will upgrade tubs end of this year so will then put out engine again as havnt got an extra 2000 grand spare for some 675rs' (think there the ones) - thinking of buying an engine lift - cheap as chips 160 quid - free delivery - bargain
