Thats it, me and Z's are over for good
Im so fu**ing fu**ing fu**ing fu**ing fu**ing fu**ing fu**ing fu**ing fu**ing fu**ing fu**ing pi**ed off its untrue.
Just started to bolt a head back on the block, got to the 8th bolt and the fu**ing block thread stripped. Just put on some £145 head gaskets and now they are fu**ing wasted.
I cant be fu**ing bothered to get it helicoiled or what ever they do to blocks, I cant afford more head gaskets.
I gonna break her now, i've jsut had enough, 2 Z's, both fu**ing crap. This supposide good one is just a pile of w*nk.
Ill get a list of bits up.
Got nice 18" wheels, gearbox, R34 brakes all round. I geuss thats the main bits.
Might be uprated injectors, will have to check. Turbos are reconditioned with 360degree bearings, not done many miles.
Dump valves HKS I think. have to check.
Spose someone could buy the engine as it is if they want? bored out with JE pistons. I just painted all the rocker covers and cam covers ffs.
How the hell o you get out a greedy e01 boost controller and safc fuel thingy??? Its all hard wired in????
FFS, I just spent £500 on a tracker and alarm!!!!!!!!
Im sooooooooooooooooo pi**ed off its untrue!!!!!!!!!!!!!!
  • Replies 67
  • Views 3.3k
It was only all done 15k miles ago. I was just checking as they said it was a 3.1ltr engine but it isnt, just the JE pistons. (87.5)
Anyway, fook it, thats what it was, long bolts in short holes. I had 16 the same length, it must have bottomed out and just destroyed the thread.
All 16 the same? :eek: You can re-use the bolts, probably best if you don't re-use all of them though ;) LOL :D
If your going to helicoil the head I think Ive still got the tool required to wind them in after the rethread If you want it I will dig it out .It will save on costs as you will only need to buy a couple of helicoils and a tap to suit.Should only cost a couple of quid to post if you want it. just send me your postal details and iuts yours
Ok, just looked at old 16 bolts and 2 shorter ones. And I was sent 16 the same length (all long)
I took the heads off and checked the two threads. They seem to be ok, I wound two fresh bolts down them, a little tight (will get a tap from work tomorrow and clean them up) but the bolts did up tight and seemed ok.
I think I will get the ARP stud set and all should be ok.
Thanks for all the support!!!!!!! :duffer: Z's are doing my nut in!!!
and come on if a turbo failed id understand but friggin ell chin up bud:p
On my last Z, I had two turbo failures and head gasket on my last one, no. 6 cylinder dead, exhuast rusted through, snapped downpipe studs just to name a few things.
So I am a little p*ssed lol!!!! :D
Fook ARP is £205, I thought it was £90 lol.
Back to the bolts. :nana2: I think ill get a loada washers and stack them up to test the two holes will go upto torque
no way, i hope your joking? dont even think about that, the bolts wont torque up properly as the washers will just compress. Get new bolts
Get the ARP's!!-worth every penny!! ;)
Bit of threadlock on the dodgy threads,sorted!! :D
Just use the 2 old shorter ones. Z headbolts are reusable ;)
I ment without the head on, I will put a load of washers on the bolt to space the gap out so I can load up the thread to make sure it holds before I go putting all the heads back on.
As the Duff man says they are reusable :D used mine 3 times now and never had a problem :)
I hope you stick with it dude, I knew the car when Tony had it and it was one of the good ones. I know how you feel tho, and I tried to get away from Z's but I'm back already!! LOL!
Stick with it, don't be afraid to ask for/accept help and you'll soon be on the road again :)
Anyway, things like this give you something to talk about at club meets and events!
Wish I just used the old ones and saved £90!!!!!!!!!!!!!!!!
oem headgaskets are not reusable but cosmetic ones are which i presume you have :)
Yes Kirbz, I have cometic h/g.
The £90 was for new bolts, then found out I could have used the old ones. I also then would of had the two shorter ones and no f**k up, lo..
im after a pillar pod to fix 3 guages, if you have one and your breakin ur zed gimme a bell on 07850694853 jason
Where'd you get the bolts from? If you explain to them they may supply you with new (and the right length) bolts free as they fwcked up.
