how to change headlamp bulbs???
from what ive gatherd its h3c bulbs that are needed to relace the headlamp low beem not high beem (ie) driving lights how do i get to the bulb with out breaking anything is there a guide or a write up of some sort on how to chang bulbes. sounds like a blond question i know :o
forgot to mention its a jap import it that makes any difference
There is no write up, supposedly it's just a case of putting your hand in there, and un-clipping it. But to be honest I've NEVER found it successful doing it that way, and have cheated by taking the headlamp out :eek:
I know it's a bit drastic, but while the headlamp is out you could also take them apart and give the inside of the glass a good clean (you'd be very surprised how mucky they get on the inside!!)
You could also do a simple mod to the dipped beam unit to convert it to standard Euro H3 bulbs (instead of H3c) It's a simple case of attaching a wire to the lamp body via one of the screws >> Here >> http://www.300zx.co.uk/forums/showthread.php?t=27029
