protoj ·
I am planning an engine swap for my zed just to do something differnt and these are the choices before me :
VQ30DET 280hp/285tq
VQ30DE-K 222hp/ 217tq
VQ35DE 255hp/246tq (350z)
all mated to a 6 speed gearbox....
my dilemma is go with the VQ30DET where little is know about it , go with a VQ30DE-k and use the extra cash to turbo chargre it
Go with the VQ35DE but will have to stay NA for a while....what do you guys think??
Why i choose the VQ line of engines is because they are 30% lighter than a VG and close to 40% lighter with the VQ35
