protoj · Tuesday at 18:48 1 day
Sorry mate, I saw your ''Name up in lights'' comment in the post on the turbo timer thread, and I could'nt resist!...Can you take a 'nit pick' at my thread for me when you get a mo dude? "Smooth Skin Tailgate spoiler..??" :p
Ta in advance for your time, which is appreciated, honest!! ;)
Dj.
