Erratic Turbo boost
- Adjust your preference.
- Select Site settings.
Safari (iOS 16.4+)
Safari (macOS)
- Go to Safari → Preferences.
- Click the Websites tab.
Edge (Android)
- Tap Permissions.
Edge (Desktop)
Firefox (Android)
- Tap Notifications.
Firefox (Desktop)
- Open Firefox Settings.
- Search for Notifications.
I Just had the cam belt, tensioners, water pump, auxiliary belts etc changed and although the car seems to run perfectly, when you floor the accelerator the turbo boost shoots to around 14psi (US model) then it drops to around 12psi, then back to 14 again.Sometimes the boost stops at 9psi, pauses then jumps to 14..then back down to 13psi and so on. It´s not just the boost gauge either as you can actually feel the "slight" hesitation. The Turbos sound fine too..anyone got any ideas ?
cheers
:o)
