Erratic Turbo boost
I Just had the cam belt, tensioners, water pump, auxiliary belts etc changed and although the car seems to run perfectly, when you floor the accelerator the turbo boost shoots to around 14psi (US model) then it drops to around 12psi, then back to 14 again.Sometimes the boost stops at 9psi, pauses then jumps to 14..then back down to 13psi and so on. Itยดs not just the boost gauge either as you can actually feel the "slight" hesitation. The Turbos sound fine too..anyone got any ideas ?
ย
cheers
ย
:o)
Do you have a boost controller or boost jets?
ย
Hiya TurboZ
ย
No I donยดt mate, niether a boost controller or boost jets,as far as I am aware itยดs 100% stock.
check your wastegate actuator feed piping for tightness/splits/obstruction/jets.
ย
(small hose on both sides under main boost pipes)
Cheers Ollie
ย
I went and had a quick look, they seemed fine at first glance but as itยดs about minus 3 out there it really was a "quick look" Iยดll do a proper check tomorrow after work. Appreciate it
ย
check the wategate solenoid connectors on either side of the engine as well , they might of been disturbed and not put back properly
Thanks Retro, Iยดll check those too ,appreciate the help
ย
