PC help!!
I'm trying to run a CD on XP,which it says on the sleeve it is compatable with
but just get '16 Bit Subsystem cannot run on Windows' ??
The file system is CDFS,if that helps! :smash:
Hmm, usually when I've seen that with something that should work with XP, it's been a corrupt executable - so a corrupt CD in this case..
It sounds like an old program if its crashing/trying to run the 16 bit subsystem so maybe it's not really compatible or as above it's corrupt.
Check if there's an updated version you can download?
isnt there a windows program compatibility program hidden away under Accessories? it lets you tweak windows settings for particular programs like the one on your CD.
Sorted now chaps thanks for the replies!!! ;)
