Silverstone excel display help
Trying to post up an excel list for Silverstone on the site in place of the scruffy one that is there at present but it looses the format and looks even worse
As I want to use Excel to record payment details ie usernames, actual names, addresses, etc it would be nice to also use part of it to show users that had paid up to go to the show
Have tried to post it up but it lost all the format and came out looking Shite
Help please pc gurus
I can fix it so that you can attach an excel file (if you can't already), but can't do much about the formatting, its a forum feature that it turns turns multiple spaces into single ones. Think it ignores tabs too. Only thing you may be able to do is use a non-proportional font and then use the code feature.
[font=system]Like fixedsys
test  test  test     test[/font]
Turns words into multiple ones too I think ;) :rofl:
an easy cop-out would be to take a screenshot of the table (zoomed out to fit it all in) and then post it up as a picture, but that'd look shite and the text would be too small, unless you paste 2 or 3 shots on top of eachother.
have you tried exporting as a CSV
...or wrap CODE /CODE tags around it
then      you     can      have as many    spaces   as  you like....
....and     a    proportional      font!
thanks for the suggestions fellas but tried tried exporting as a CSV I think and it came out shite
"...or wrap CODE /CODE tags around it " remember I'm old and that stretches my mind a bit
Any chance in idiot talk please
simple, anything you write between
 tags on here appears like it does below. so if you export your spreadsheet into a tab-delimited text file, then copy and paste it into your next post on here, then put [code ] at the start, and [/code ] at the end, it should appear as below:
[code]
FELLA	OWED
john	£15
kev	PAID
bob	£15
dave	PAID
ed	£15
frank	£15
gray	PAID
I cut'n'paste from Excel for my membership lists and that comes out messy. Can't remember the reason now, but I think it may be something to do with a combination of tabs and spaces. Exporting as fixed length records that are padded with spaces should work - is that possible ?
136	samuri-240	240Z
137	miniman	350Z Roadster
138	Netpreference	260Z 2+2
139	Ian and Shelia Hill	300ZX Z32
140	babydoggen	260Z
141	nickc	300ZX Z32TT
142	BigDaveZX	300ZX Z32TT
143	grem	300ZX Z32TT
144	grem	300ZX Z32
STILL A senile old sod will try later on
ok try this, when you save it from Excel, save it as "Formatted Text (space delimited) (*.prn)"
make sure that your columns in the spreadsheet itself are wide enough to accommodate the longest username.
then, exit Excel and rename the .PRN file that you just saved to .TXT, then open that!
