Cost to supply and fit the following:
Racelogic traction control (with digital adjustment)
Boost controller.
Please let me know the range of boost pressures the controllers will work at, as I want to turn boost down when my Mrs gets behind the wheel.
on a side note, is it safe to drive a TT with 0psi boost? what would be the effect on the engine and what sort of power would it produce? I am guessing it would be less than a standard n/a.
Can only set turbos to 7psi minimum as this is what the wastegates open at.
Boost controller.
Cybernet would probably want to help you with the TC install, I would but I don't have much spare time these days.
Simple way to sort the boost problem is by having a custom switchable ECU chip with "his and hers" maps. You have the full welly version and she has the restricted speed and revs etc.
Thanks for that Andy, I have just got a pm from Cybernet and will pm him back in a mo.
Where can I find out about switchable ECU's? Who supplys them, and how do you switch them?
I've done a few for people, just a simple switch that hangs out the ECU on a cable. I keep mine tucked under the carpet as you don't need to change it often.
Not exactly, but a combination of the two would probably be best.
Thanks guys,
Any idea on the price to supply and fit the ecu and boost controller?
Thanks guys,
Pm John Dixon he's da man!
