loss of power
i have a problem with my ZED when it get's tto just undre 6000 RPM it's like i've come off the gas. The car has been chiped and had boost jets fitted by ZED WORLD (runs at 14psi) it also had this problem before i had the boost tuned up.
might be faulty lamda\o2 sensors or a leaky intercooler.. or a leak in the turbo system piping.
Sounds like the car is hitting the stationary rev limitter. Get a conzult on it and check the ecu is picking up the speed signal
the car has had new turbo's so all the piping has been off and back on. had conzult's no prob's it seem's to get better the more you put you're foot down maybe the zorst is geting blocked? i know it can still do a DB9. ha ha
Maybe the tacho is wrong and it's hitting the 7000rpm rev limiter ...
Sounds similar to a problem I had last summer. If you lift your foot off the accelerator momentarily and then whack it down again, does the car take off again for a bit? If so then I had this but at slightly lower revs and it turned out to be a loose boost pipe and was quite hard to spot until I decided to have a closer inspection and check they were all pushed on correctly.
Gaz
