right can i put my seat belts back on the doors as my new interior has them on doors mine hasent they have been changed- they would of been on doors to start with but have been moved how can i tell if the doors are the same and can take the seat belts thanks
The later cars had seat belts on the pillars not on the doors.
Sounds like you're trying to convert it back with the wrong interior...
Not sure if the belts etc are the same.
Is it an import didnt all uk cars have normal fitting seat belts if there uk doors i dont think they will have the bolt holes in for the seat belts in the doors i could be wrong though.
Chris converted them to uk / j spec series 2, You will need the j spec series1 seatbelts as they are different, You will also need the top mounting spacer.
cheerz, mickey
Who is? :confused:
Theres at least two threads on this subject in two diff sections ;)
Someone is sending the full set-up to Tony, so hopefully everything should run as clockwork :D
