putting seat belts back on doors
hey gang noticed chris moved seatbelts to the pillars as in the s2 zeds my new interior there on the doors so will have to put them back how can i tell if its still the same doors and i can get the seatbelts back on them thanks tony
On the door pillar there should be a plastiic plug on the outside, take this out, undo the screws behind it and the interior pillar trim will clip off. Behind this you will find the mounting point for the seat belt.
On this same fixing point Nissan made a upper door latch, if it's not there you'll also have to get hold of one along with the fixing onto the bodywork for the other half of it.
There should also be a bottom fixing for the seat belt lower fixing point on the bottom of the door. But this would be below the door trim.
Chris must of gone to a lot of trouble to mod the seatbelts, as there arn't the fixing threads within the B pillar. The holes are there, but the threads arnt. So he would of had to weld threads in. A whole load of work for very little reward (IMHO)
Dave
Lower fixing point shown on this pic...
Upper fixing point shown in this pic (just)...
on the bottom of the door there is one big bolt hole and a little way along the is to holes that have little plastic clips in them ?? as for the upper bracket the body work piece is there but not on the door will i definatly need this then ???
year hes going to throw in all the hardware and brackets anyway so thats cool - hey dave wasnt it you that gave me the link to this interior ???
