Me again.
So I have two questions:
RobHowl ·
Just ordered a set of these from the states off Fleabay with pads for $399 (200quid).
This includes front and rear slotted/drilled rotors and a full set of pads,including shipping to the UK,beat that
http://cgi.ebay.co.uk/Nissan-300ZX-91-96-F-R-DRILLED-SLOTTED-BRAKE-ROTORS_W0QQitemZ330077751783QQihZ014QQcategoryZ31490QQcmdZViewItem#ebayphotohosting
V12 Motorsports
Nissan 300ZX (91-96) F&R DRILLED/SLOTTED BRAKE ROTORS £75.73
An eBay Shop maintained by: v12motorsports( 241) Seller, manage Shop
