In memory of Mandy
PC help please!
Ok a couple of weeks ago I had to reinstall windows. Now whenever I try to access the music/pics etc that were in the 'my documents' directory it just says access denied. How do I get the data out of that directory? I'ts got some pics in there that I need to sell something!
when you reinstalled windows you just installed windows over the top didnt you, leaving the files on the drive.
When you installed windows you created a new user account, your my docs folder belongs to your old user account. = access denied!
dont you just love ntfs file permissions!
You need to take ownership of the directory in safe mode mate
had the same before, you just have to change permission to your acount. will have a quick check on line and post a link for you
How to take ownership of a folder
Note You must be logged on to the computer with an account that has administrative credentials. If you are running Microsoft Windows XP Home Edition, you must start the computer in safe mode, and then log on with an account that has Administrative rights to have access to the Security tab.
If you are using Windows XP Professional, you must disable Simple File Sharing. By default, Windows XP Professional uses Simple File sharing when it is not joined to a domain.
For additional information about how to do this, click the following article number to view the article in the Microsoft Knowledge Base:
307874 (http://support.microsoft.com/kb/307874/) How to disable simplified sharing and set permissions on a shared folder in Windows XP
To take ownership of a folder, follow these steps:
1. Right-click the folder that you want to take ownership of, and then click Properties.
2. Click the Security tab, and then click OK on the Security message (if one appears).
3. Click Advanced, and then click the Owner tab.
4. In the Name list, click your user name, or click Administrator if you are logged in as Administrator, or click the Administrators group. If you want to take ownership of the contents of that folder, select the Replace owner on subcontainers and objects check box.
5. Click OK, and then click Yes when you receive the following message:
You do not have permission to read the contents of directory folder name. Do you want to replace the directory permissions with permissions granting you Full Control?
All permissions will be replaced if you press Yes.
Note folder name is the name of the folder that you want to take ownership of.
6. Click OK, and then reapply the permissions and security settings that you want for the folder and its contents.
Back to the top Back to the top
How to take ownership of a file
To take ownership of a file, follow these steps:
1. Right-click the file that you want to take ownership of, and then click Properties.
4. In the Name list, click Administrator, or click the Administrators group, and then click OK.
The administrator or the Administrators group now owns the file. To change the permissions on the files and folders under this folder, go to step 5.
5. Click Add.
6. In the Enter the object names to select (examples) list, type the user or group account that you want to give access to the file. For example, type Administrator.
7. Click OK.
8. In the Group or user names list, click the account that you want, and then select the check boxes of the permissions that you want to assign that user.
9. When you are finished assigning permissions, click OK.
