protoj · Tuesday at 18:48 3 days
ME Again,
Another problem I had at the weekend was with the cruise control. I could put it into cruise mode from the dash switch and the "cruise control" light comes on but when I try and engage it the "cruise" light just flashes and nothing happens.
Any ideas.
Cheers,
HARTY.
