Fan Freekin' Tastic!
How do I get this broken screw out? The head snapped off wasn't even tight at the time.
Tried grabbing it with mole grips and twisting but they just slip off. Tried twisting from the inside using those thin plier things and that don't work either. I'm sure it should just come out easy no idea why its so stuck.
Cheers,
Al
Now if you read the manual i'm sure it says something about some jap batteries are different in size on the connectors. If smithy's about he might be able to tell you what to do.
Dip the terminal in some boiling water and try again with your mole grips.. or heat up around the bolt ( dont heat up with an flame near the battery )... worth a try
Yeah I read that but I don't think its a jap battery and the connector fit over it perfectly. It just broke when I was tightening it....
Cheers people I'll give some of those things a try.
Al
Pull it off battery and hacksaw a screwdriver slot in it.
Actually this one's genius! Will try this tomorrow thanks.
please take that to heart ive seen what can happen. heat up the screw as stated, always worked for me
