cruise control? optional extra or standard!
As above really, only had mine a week and has had an uprate wheel fitted and now there is now cruise control buttons if it is even fitted.
It was standard on some years, and optional on others. If your car originall had cruise then there will be a button on the Right hand pod for it.
Cruise control was a option from new alot have it, not sure if it was standard on uk cars .Later on in production it moved from the steering wheel to the stalk on the coloum.
okay I have a 1991 jap spec tt would that have cruise control or not what is the quickest way to check? bear with me as I am a new to the car
It was standard on some years, and optional on others. If your car originaly had cruise then there will be a button on the Right hand pod for it.
cool will check thought they were all on the steering wheel that was all.
Pop your bonnet , there should be a unit bolted to the n/s strut top with a cable going to the throttle linkage meaning you should have two cables all together ( throttle and cruise ) HTH
Cars with cruise have a switch on the pod to turn the Cruise control on/off, and then buttons on the steering wheel to set/control it.
