aftermarket aerial location
I want to fit a DAB aerial antenna to the exterior of the car and dont know where to put it. I need to keep the existing aerial for FM so i suppose the obvious point is in place of the rear washer jet but i will be sorry to loose that. Is there anywhere around the t-tops that could be used. I would rather be making holes in plastic bits that can be replaced than drilling into the car body. Will also have to be able to string the cable from the aerail to the head unit. Any ideas?
you can remove the existing arial - the screen arial should be good enough for your FM (at least it is if it's fully functioning).
Rich
