January 6, 200719 yr hi guys is there an faq for converting my jap spec seatbelts into 3 point ones any advice welcome thanx
January 6, 200719 yr Not really an FAQ, but I'll try to help, as I fitted them to mine late '06. Once you've taken the quarter panel off you'll end up with this. All the holes are there in the proper places along with threads within, the lap belts uses the bottom one at the moment. You'll have to remove this panel (along with the boot dampners, be VERY carfull here) and drill the hole, it's already marked on the reverse of the panel. Then re-fit the panel Now all you have to do is trim the quarter panel in one place only..... Fit the belt in place and torque up. Place the quarter panel to where it will fit, and make a mark of where the belt crosses it... Trim this with a sharp knife about 5mm into the panel, try the fit again and make sure the belt will run properly, if not trim a little more. If it fits OK, then you now need to make three small holes for the trim plate. With three holes drilled, fit the trim and hold fast with the pop clips. Now fit the quarter panel back in place.... Job done. Just another image for you... HTH Dave
