my Z pulls left when braking hard
Hey all when i brake hard at about 60/70 plus i get a bit of a gudder sometimes and pulls to the left, im not that confident with the rear wheel drive yet so this does t help any ideas its a uk TT, Many thanks people :duffer:
Lack of braking force on the front right, ie seized calliper or a buckled flexi hose.
Calliper service kits are available from Mike Feeney (MJP) in the traders section, quite an easy job to do yourself, as long as you follow the instructions (which are on an on-line link that I cant lay my hand on at the mo)
I'd also get new pads, and check out the discs while you're there. Also do the whole job while you're there and sort the rears (even easier).
Being able to stop is far more important than anything else, unless you're a suicide bomber!!
also juddering will prob be discs or worn tension rod bushes
I'd go with tension rod bushes tbh if its only at high speed. Classic symptom is juddering under hard braking from speed. If just one has gone then the wheel may well be pulling itself out of alignment and causing the pulling to the left...
