Is there anyway to get pops and bangs
Hello Again,
I used to have an RX7 and when i used to decellerate it used to missfire pop bang e.t.c is their anything i can do to my zed to recreate it.
Bit strange i know but thanks for reading
you dont want to much pops and bangs, fit bovs and you might get one or two when you lift off boost and the bovs dump and its still fueling for the dumpes airmass
When i had my celica and i got a cat-back exhausts and a K&N fitted it used to pop and bang on deceleration but thats just unburnt fuel? I probably needed to have the ECU remapped or somthing?
if you remove all the recirc setup and bung it up you may recieve the odd pop bang, but its not good for turbo's as everytime you lift off change gear you will have air rushing back through the turbine stalling it. Does sound sweet though. also will kill your catalyst very quickly as you will have more unburnt fuel entering the exhaust.
if theres a man on here who no,s his stuff its greg,so take notice and DONT DO IT TO A ZED :headvswal :wack: :x: :D
With a zed you will get pleny of pops and bangs, you have two turbos which will go pop sooner or later, not long after that the 3 litre engine will go bang!!
Id get a box of fireworks if i were you, much cheaper!
