Wiper and Bulb help please
I went to halfords and bought some new bosch wipers, Checked with the girl that they were for the 300zx and it came up with size 21/21s for the front. When i put them on, the drivers side overlaps by about 1.5" so it catchs it on the passenger wiper on the way up.
Does anyone know what size i need and as mines a jap import does that make any difference? Its a G/1990 model.
Same as above again with bulbs, bought the recomended "super brilliance" bulbs size 448sb which is what is says in the book are for the 300zx but when i removed the bulb from the car its a single pin bulb and these new ones are double pin.
Going to pop back up there to refund them but if anyone knows which one`s i need then ill just change them over.
  • Replies 27
  • Views 1.2k
These are very white bulbs but do have a blue "fringe" tint (if that makes sense). Incidentally, these are the same bulbs as Autobulbs Direct sell (only cheaper ;)) They are rated at 4500K so not quite as white as a 6000K HID kit (but pretty close).
Dan
How much is your hid kit as your website doesnt let you search them.
Do they fit on a jap car the same as the uk car kit aswell?
Whilst out in the garage having a fag I think ive sussed the wiper problem.
The blades should both be 21 inch, not handed.
But the Arms ARE handed, someone has probably had the arms off for painting as they go abit weathered, then put them back on the wrong sides.
Try putting the 21 inch blades on and swapping the arms over, should be problem solved
Ill have to have a look at that as they have never been repainted as far as i can see, paints starting to come away and looking pretty faded to be fair.
But they might have been off for some other reason so ill try to swap them over.
