Window Control Switch
Hi
Just wondering what controls the single press up/down control on the drivers side window? The windows still work fine but it's just the dingle press up/down has stopped. I have removed the relay unit and re-soldered a couple of dry joints and both relays in the unit are clicking away. Any ideas???
Vijay
i thought it was part of the switch, i would say the switch has gone maybe
I resoldered one of my contacts in the unit, and it worked for a while, then packed up again. So i resoldered ALL the joints and it's still working, so far ;) So I'd sugest just doing the whole lot, if that don't work, get a new one :D
Thanks guys. Just resoldered the joints so fingers crossed :)
Vijay
  • 2 months later...
does nayone know what these 2 parts are from the driver side door?
The one on the left is the window control modual. The other one looks more like the 'Lights Out' relay from the rear right hand light cluster!! :confused:
Cheers Dave. Do you know if the one on the left controls the one touch operation on the drivers sie?
Vijay
does anyone know how many components make up the electric windows? As far as I can tell there are 3 parts - window switch, window amp assy and window regulator unit?
Vijay
Yes it does. There are two small relays within this modual that control the drivers window regulator motor.
Correct. Wiring page here >> http://300zx.co.uk/cgi-bin/manual.cgi?list=bf&dir=&config=&refresh=&direction=forward&scale=0&cycle=off&slide=12&design=default&total=46
HTH bud.
Dave
Cheers Dave. Any ideas what the regulator looks like? In fact, why don't you just come and fix it for me!! lol
you mean the manual page like you posted?
that's for the actual motor isn't it?
