In memory of Mandy
best oil to use eng, gbox and rear diff?
best oil to use eng, gbox and rear diff? off to buy one tomorrow and want to give it a quick service whats the best oil people use in theres
i have got some mobil 1 15/50 fully synthetic is that any good and how much do they take 93 uk tt model
cheers
Nissan recomendation is
Engine 10W/40 3.4ltr with filter
Gearbox 75W/90 API GL-4 3.1ltr
Diff 80W/90 API GL-5 2.1ltr
Any good quality oil, either fully synthetic or semi synthetic will do.
I'd sick to a fully synthetic for the engine oil, personally I use valveoline
duratec
it only uses 3.4ltrs?
also would Mobil 1 Motorsport 15w50 be fine to use?
greg says 4l for engine w/filter, i guess he's done a few so i'd go with that.
its 4.1 ltrs thats prime,in the oil filtre as well,im using 10\40 semi magnetech at mo,but am changing to fully synyhetic for the winter prob a 5\40 or 5\50,doin it sunday and changing my auto box oil as well,usin dexron3 fully synthetic,if i get time want to change my diff oil as well,hope this all helps bud :)
Where can you get fully synth dexron 3, and how much is it. Want to start putting synth in mine?
hi mate,you can get it from most good motor factors,costs around £20 for 5ltrs,make sure you ask at the counter,hope this helps :)
Yeh cheers, how much does the box hold?
7.1ltrs,but u only manage to drain out about 3ltrs as the rest is in the auto converter,some say to change it again after 100 miles,that way u hav nice fresh oil in the auto box,done mine today and will do it again after xmas,hope this helps bud :)
Yeh, helps a lot, cheers m8!
