swb lwb washer bottle
why is the swb washer bottle in the boot .I thought the swb was the same at the front end .I wonder why nissan done this.
helps get a better weight distrbution. One of the many little details taken in to consideration when designing the 2 seater.
an annoying factor in the design of the swb is that you dont get a full tool kit in the boot either!
My SWB has two tanks, 1 in front and 1 in back. Each tank also has two motors and will transfer water from one to the other.
Thats not factory is it ?
Sure is factory (it's a jap import)
mine dont have two bottles seems like a modifiation to me
Mines a 1991 swb slicktop tt and it only got the 1 washer bottle in the rear .It has an expansion tank under the front wing .
you should have a rear washer bottle in the n/s/r wing by the light unless you dont have a rear washer ?
Mine is an 89 and I definately have two bottles, 1 front and 1 rear. As mentioned before there are 2 pumps on each tank, one for the washer and one for the transfer. All wiring looks factory as does all piping, including the clips holding the pipes.
Perhaps it had a smack in the front (not that I can see any evidence of this) and the repairer installed a front tank.
But that wouldn't explain the wiring which looks original. Will take some photo's tonight (weather permitting).
this is quite an interesting find. would like to see the pics mate.
I've definatly seen quite a few SWB's with Front washer bottles (In fact dont recall seeing one without)....never paid to much attention before but will check out the twin motors
Front tank filler
Can't get photos of the front tank with out pulling the car to bits
Two rear pipes
Rear tank filler
Rear tank
hummm i dont know why mine doesnt tho! :confused:
I only only have one as well :confused:
I must say I was surprised especially when I found out how it all worked together.
Use the front washer and it also transfers a small amount of water from the rear bottle to the front. The reverse happens when you use the rear washer.
Very hard to run out :)
As I said before it "looks" factory but it may be a creation of some Japanese "enthusiast".
