traction control settings
mm I'm strugling with the wheel diameter size, as the program for calculating the size from the tyre size only goes as low as 30 series and my car is running with 25 series, unless someone can give me the exact mm diameter for 315/25/19??
richard
To get Clarkey's answer (from TT.net)...
(width x profile / 50) + (wheel diameter x 25.4)
This will give your tire size in millimeters. Such that for the stock 245/45/16 rear tires, you will get the following...
(245 x 45 / 50) + (16 x 25.4) = 627 mm (so enter 00627 for driven wheel diameter)
Steve :)
'93 UK TT Manual
