Where is the best place to get a set of decat pipes from ?
I looked on ebay some there for £129 anybody bought some and where from THANKS
Oh and how do you stand with the british law Just want to make sure I have a 91 so i think i am ok ??? (I been told its after 92 that you cant get rid of the cats) Like most of you out there (YEAH RIGHT WINK).
if the car is a 91 then you are fine to remove them.are the flea bay cats the ones sold by 2fast2cool? as i have a pair and am very impressed with them.the pipes come with divorced dump pipes which are said to aid spool on the turbos.
i have been told if its 94 or before you can get away with decat's
Thanks going to bid for them :-)
Whats a PVC kit ?
Positive Crankcase Ventilation.
2 valves and 5 hoses
They recycle crankcase gases into the intake. if they become blocked they can cause an oil pressure build-up, which combined with loss of back pressure from de-cat could cause turbo seal failure.
They cost about £80 ish! from MJP i believe.
Found a link to help you change them : http://www.ttzd.com/tech/pcvtech.html
