Speaker issue
Hello all, it's been a while since I last posted, I have 2 questions.
1. For some strange reason, only one speaker is working, the centre one and not sure why, everything in there is standard.
2. Is there a fuse for the feed into the centre speaker because when I was trying different speakers I think I blew the fuse, the radio comes on but now there is nothing from the centre speaker. Sorry for all this and any help would be much appreciated.
errr...then someone has added the speaker and the wiring since the car was built....
If it's under the head unit then surely tracing the wiring is easy ?
There are three blocks, two for the head unit and one for the centre speaker, then the one from that speaker traces back to the mass of cables which go to the head unit, I thought that speaker was standard, it has BOSE written on it
the centre speaker was standard on some models
if you post lwb / swb and jap / uk and age of car it could help as well as is the head unit / other speakers still stock ones. maybe a photo of your wiring?
a lot of the bose speakers had built in amps in or near the speakers which take power from the headunit. from memory i think the power for all of them came from one connector on the headunit.
i'm a bit confused from your discription which bits are / are not working from your description
[sIGPIC][/sIGPIC]
Ian, would it possible for you to have a look at it? Seeing as you're quite local, i'm from Woking
ok , sure i'll have a look
[sIGPIC][/sIGPIC]
