Got myself a plenum to polish , got the throttle body,s off and as expected it,s full of oily gunge , any one used any product that would shift it , if not gonna cap the openings and swill it out with petrol !!! :D
Alan, spray it with some carb cleaner, that will shift it matey, put plenty of rags down tho!!! :D :D
I used carb spray as well.Also get's bitumin(tar) off your hands too as i found today. :D
If you want it really super clean put it in a high pressure parts washer, then after it comes out spray some brake dust cleaner on the openings, wait ten minutes then use a high pressure spray and every spec of dirt should be off by that point.
Check out mine....
And when you put it back together do away with the pcv valves and do a oil catch tank upgrade to stop all the oil/crap going back into the plenum and throttle bodies again.
I had mine sand blasted, & chemically dipped. Came up a treat :)
Same here.
