Help needed
hello,
I'm on contact with a factory in the USA for a carbon crankshaft and here is a question from their technical:
ย
I spoke again with my tech and he advised that he does not have the dimensions on the 2+2 manual transmission and we would require a seal to flange measurement from you. Also, he asked if the flange was a 6 bolt for CV joint and the spline count on the trans yoke is 30.
ย
Even if I'm a French speaking english, i don't understand what they mean :headvswal :headvswal
ย
I do understand for the 6 bolt and answers is yes but the other one...
Basicly he is asking you how long the shaft is from the flange on the diff to the oil seal on the back of the gearbox, and also on the gearbox end how many splines it has. (splines are the slots cut into the end of the shaft that slots onto the gearbox.
ok but i'm offshore africa so if someone could take this mesurement :p
