hicas track rod arm question
hi all
:cry:
i am having a problem with my car, i thought it was a rear bearing away, on the drivers side but once i have got the car up in the air i can see thats its actually the arm that links the hub to the rack itself. the play is in the ball joint at the end of the rack. and is clearly visible when the wheel is moved
my question is this, i have a elimination bar to go in but, will i still need to replace this arm? how do i get it off and can it be simply tightened up? i have put a big spanner on the socket side of the joint that looks like a big square but it just turns the whole shaft through the rack,
can someone please shed some light on my problem.
cheers
richard
Just replace the balljoint - contact MJP in the traders section or http://www.mjpauto.com ;)
Oh and I think with 612 posts I think its time you subscribed ;) LMAO
The sqaure nut under the gaiter should undo without spining its 30mm they are normally thread locked on so maybe tight .You have to use a balljoint breaker on the hub end you will need to replace the hole arm .And yes it still needs doing even with a hicas lock bar .
lmao how pissed were you in the early hours? look again! 2nd year mate
Wasn't pissed at all mate - it honestly said registered user! :)
hi all
:cry:
cheers
richard
put a spanner on both sides of the rack.you need to hold one side to undo the other.
You didnt on the electric rear hicas rack i removed the arms from havent tried a hydralic version.They came undone one side at a time .
andy how bizzzar?
i have a new set of arms on the way to go with the eliminator bar!
Yep had to do this on mine. One spanner on each side of the rack. Once one comes off then there's a flat I think that you can put a spanner on and undo the other side.
Ivan
Just found this whilst reviewing another thread!
HICAS Eliminator for 90-96 300ZX....
Found under 'products' section at... http://www.escort-us.com/frames.html
Needed if HICAS system is disabled or removed.
304 Stainless Steel , TIG welded, and weighs 2 lbs.
Banjo fitting also available if needed, sold separately.
Skyline, Sylvia, 240SX version also available.
