Hicas light comes on now and again
Hi does anyone know the cause of my hicas light coming on it only does it now and again, could it be low fluid level, or maybe a sensor there are no signs of leaks anywhere on my drive any advice would be great . many thanks :headvswal
top it up with dextron 3, happens now its started to get colder.
my light comes on 2, also does anyone know what on earth is causing my speedo to jump and go mad??????
Dexron II or III type Automatic Transmission Fluid from any car spares place or most petrol stations.
Goes in the green pot on the drivers side wing ;)
Thanks for the info guys , mine is a manual will i need automatic or manual transmission fluid as stated above seeing as my hicas light is on, is that the type of fluid my hicas system runs on. Many thanks :headvswal
Yes it's ATF - just used as hydraulic fluid for the power steering :)
