uk speedo probs need heeelp
My speedo has been playing the jumping game @ 40mph then up to 60 etc, have been able to rectify in past by tapping the head with cover off.I've researched posts and thought i'd give resoldering a go, have reconnected, turned ign to acc, the needle jumped to 40 and reset itself,ok i thought, left it cos dark, today needle straight round to 180..ain`t budging,this is before the car`s even started, moved it to zero by hand..nothing,have borrowed a set of clocks in past, all worked ok so not the sensor,will check connections again but methinks tis buggered,any ideas anyone? :mad:
I have got the same problem as you. Speed sensor has been changed so not the problem. What have you tried so far and which posts have been helpful?
hi,well so far just the soldering,have cleaned all contacts but to no avail,still static.i`m sure it`s the dial itself prob just naff component somewhere on board my ability to solve leccy probs is limited so think i`ll buy another to save on grief ...money pit,more like money wormhole....whoosh there it goes!
[oh n just search under dead speedo or soldering you`ll get loads of results general consensus was re solder everything on board
